Search instead for
Problem with installation on Home / Build / Automation with Dashboard API
1. I am new to Meraki and trying to learn via the tutorials available on Developers.meraki.com.
2. I am on a MacAir and navigated to Home / Build / Automation with Dashboard API
3. The steps listed are below.  The install is failing on step #4 with the error message "
pip3 install --upgrade requests
-bash: pip3: command not found
What should I do?
thanks
For macOS users:
  1. Install Homebrew first, if not already present, in terminal:
    ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
  2. Install Python 3.6
    brew install pyenv
  3. Install PyEnv
    pyenv install 3.6.5
  4. Install the requests module
  5. Install Dashboard API module
    pip3 install --upgrade meraki
  6. To make sure your installation is successful, launch Python
    python3
  7. Now you should see the >>> input, and you can interact with Meraki with a request for the list of organizations
    from meraki import meraki
    meraki.myorgaccess('e24759c28edd1d97715a6ba9ea8bc679c5d2706b')
  8. You should see similar results being returned:
    {'id': 578149602163687854, 'name': 'Public API Lab'}
Re: Problem with installation on Home / Build / Automation with Dashboard API
Pip3 is part of the python install. Was that succesful? What is the output for:
python --version
Perhaps try restarting the terminal or the laptop as a whole.
Thank you for the quick response.
1. Yes command #3 i.e. pyenv install 3.6.5 completed okay
2. Tried restarting laptop and re-running command #4 i.e. "pip3 install" , got the same error "
pip3 install
-bash: pip3: command not found"
3. Tried reinstalling 3.6.5 and rerunning #4 - same error.
pyenv install 3.6.5
pyenv: /Users/rohithans/.pyenv/versions/3.6.5 already exists
continue with installation? (y/N) y
python-build: use openssl from homebrew
python-build: use readline from homebrew
Downloading Python-3.6.5.tar.xz...
-> https://www.python.org/ftp/python/3.6.5/Python-3.6.5.tar.xz
Installing Python-3.6.5...
Installed Python-3.6.5 to .....
Not sure what to do next.  Am also trying on a Win10 environment.
thanks
What about "python --version"?
1. Response to entering "python --version" was Python 2.7.10
2. Tried the suggested installation for Win10 - worked like a charm.  MacOS still an issue..
thanks
Are you using Anaconda or Miniconda on the mac? Try the one you are not using. I expect serpentine labyrinths when playing the snake charmer these days.
https://conda.io/docs/user-guide/install/macos.html
I have a feeling it's using a pre-installed version of python on your Mac.
Try issuing the following command:
pyenv global 3.6.5
1. Yes it is.  Reading up on the MacOS, python 2.7 is bundled with MacOS and it doesn't show up under Applications, and there is a caution against removing it.  Just upgraded the OS to the latest version Mojave 10.14, but the default version of python remained unchanged at 2.7.10.
2. "pyenv global 3.6.5" did not result in any confirmatory message or any error message.  However python --version still displays 2.7.10 and "pip3 install --upgrade requests" still errors with "-bash: pip3: command not found"
thanks
Yeah indeed, removing it would probably be a bad idea.
Unfortunately I haven't got a mac myself, so I'm a bit in the dark here. I'd guess something went wrong with one of the steps. Because as far as I understood from the docs the pyenv global command should make the mac use the version you specify as default from then on. So the output of the python --version command surprises me, it shouldn't be outputting python 2.7.1 anymore.
What's the output of:
pyenv versions
