Sure i missed something with the use of the Meraki Dashboard :
From a php server or Postman, while i can retrieve info from a request like GET /organizations/{id-org} or GET /organizations/{id-org}/networks/ or GET /networks/{id-network}, i can not get anything from a GET /organizations/[id-org}/networks/{id-network}/devices or GET /networks/{id-network}/devices !
I have 2 managed networks, one of 60 devices, the other with 600.
Any of above requests reply a 200 OK Status, the devices requests send me a null array
What should i check in the dashboard ? Is there a parameter i missed ? Something else ? Any help is welcome !
Solved! Go to Solution.
Bingo! That API is for Meraki hardware, like switches, security appliances, etc.
You want to use:
GET /networks/[network_id]/sm/devices
Are you 100% the NetworkId you are query contains devices?
/organizations/{org_Id}/networks returns 2 networks, wich i can query each one with /networks.{net_Id}. So i am sure with the ids.
On the dashboard, i select one, I click on "Clients" in the "system manager" menu, so I can see my devices (60 in one, 600 in the other) ...
You want to use:
Indeed this query replies something ... :
{"errors":["This and many other features are available in the licensed version of Systems Manager, as well as 24x7 phone support. To start a no-commitment trial of the full version of Systems Manager contact your Meraki sales rep."]}
haha 😞
Anybody has an idea of this kind of cost ?
Thank you anyway Philip for your help
The cost can very considerably depending on things like volume and weather it is education/charity or not.
Either contact your favourite Cisco Meraki reseller or from the Dashboard go "Help/Get Help" and scroll to the very bottom. It has a section labelled "Cisco Meraki Sales". Contact that person for a referral.
