Meraki API - Wireless health
MartinIndu
I'm trying to use the Wireless Health API methods of Dashboard API and I recevie 404 error.
For example this methods:
/networks/[networkId]/connectionStats
/networks/[networkId]/devices/connectionStats
However I can successfully call other methods for the same network and using the same API Key, such as:
Is there any limitation or anything special with those methods? I've read some posts saying they are beta, however I can find them in the dashboard documentation.
Thanks in advance
jdsilva
I was told yesterday that Meraki needs to enable the API on your networks and they're not generally available yet.
I believe that's correct, please call into Meraki Support to enable this and confirm the proper settings and firmware to see if the Wireless Health API can be enabled on the back-end before it's generally available.
aws_architect
I feel like all functions need to be activated via support .
I have like 10 stuff that I had to request , even very very old feature that never got released !
If you don’t read there and there then you cannot know this feature is even possible !
