Search instead for
MV Sense MQTT Connection
   I'm just trying to use the new MV Sense API via MQTT and the works well. I have only one problem with authenticated MQTT server, I know I can put a CA Certificate but I need to specify username/password.
Someone knows if there is a plan to add this feature?
1 REPLY 1
TMD
Re: MV Sense MQTT Connection
Hi Webfrank,
I'm trying to use cloud based MQTT for the same, but I cannot add my credentials to Meraki MQTT connection configuration.
Were you able to authenticate with username and password?
