Search instead for
How to retrieve VPN traffic metadata from Hubs via API
We're in the process of deploying MX to our branches and one of the things I routinely do is inspect the "VPN status" page of the hub under Security appliance -> VPN status .  This is helpful to me during implementation because deploying the MX65 and connecting it to the ISP is separate from actually getting traffic to route across the IPsec tunnel that it creates to our hubs.  By looking at this page I can see how many new sites have come up from one day to the next and I can also see whether or not a particular site is missing other configuration required to get the site fully broadband-enabled (by sorting Usage from low to high I can tell if a site is not fully enabled because the traffic is none to very low).  I cannot find a way to pull this info down via API.  Is this possible?
1 REPLY 1
Re: How to retrieve VPN traffic metadata from Hubs via API
No.
