Search instead for
Get MAC address of nearby client device
Is there a way through the API to get the MAC of a device that shows up nearby? For example, setup an AP that's just listening and obtaining MAC of nearby clients. I can see devices in the location heatmap and live presence, but can't find a way in the API documentation that allows me to find this detail.
Thanks in advance
Re: Get MAC address of nearby client device
You need to use the location analytics API.
https://meraki.cisco.com/technologies/location-analytics-api
This whitepaper has very detailed information about it.
https://documentation.meraki.com/MR/Monitoring_and_Reporting/Location_Analytics
I what to do the same thing, but it Seems that the SmartPhone device change there MAC Adress every time there connect true Bluethoot as the MAC address show in the Meraki Portal don't mache with the mac in the Smartphone.
