Search instead for
Dashboard throughput API
My name is Jonathan.
I'm doing a test with PHP together with the Meraki API.
I would be needing extra information about the possibility of performing a speed test (throughput) for each organization within the panel.
In the documentation I don't see anything related to this test.
Can you tell me how to proceed?
Greetings .
2 REPLIES 2
Re: Dashboard throughput API
There is no such API to do this test.
Also this is a test to the Meraki cloud.  You can't put a lot of faith in this measuring the actual maximum thoughput of your ISP circuit.  It is just a general guide.
Thank you very much for your reply.
In any case I will look for some macro for the web browser to do it in about 2000 Organizations
