Claim multiple devices in single POST request
leegoss
Hi Guys,
I'm new to scripting / APIs and am struggling to find some additional information on the 'Claim a device into a network' POST.
All i'm wanting to know is it possible to claim multiple devices in a single POST request and if so, what is the correct format.
ie. something like
{"serial":"Q234-ABCD-5678”, "serial":”Q345-ABCD-1234”, "serial":”Q456-ABCD-6789”}
Or a delimited string of serials.
{"serial":"Q234-ABCD-5678 Q345-ABCD-1234 Q456-ABCD-6789”}
You can create an action batch and batch together the API calls.
https://developer.cisco.com/meraki/api/#/rest/guides/action-batches/
Seshu
@leegoss Action batch would be the simplest way.
I also tried a UI like dashboard where you enter Serial or Order#, one per line and it can claim in one go. Navigate to the Org -> Inventory -> Claim
https://drive.google.com/open?id=19Pr_7b4UP0A0zpcXCjn23S-6AbbTQa1B
TonyC
We just pushed a change that allows an array of orders / serials / licenses via the claim endpoint directly! Docs will get updated but if you want to try it out now, here are the supported parameters (notice they are now plural, and formatted as an array):
https://dashboard.meraki.com/api_docs#claim-a-list-of-devices-licenses-and/or-orders-into-an-organiz...
#wishgranted 😉
