Search instead for
Cisco Catalyst switch config import to Meraki Dashboard to configure MS switches
Is it possible to import a catalyst switch configuration on meraki dashboard to set up an MS switch?
As I understand, similar thing is possible to import ASA config to an MX using ciscoconfparse.py.
Please suggest the steps, if this is possible to do.
Thanks,
Vibhati
