Search instead for
Captive Portal API - Click-Through - Can a email address be passed to the API
Just browsing
I tested the Captive Portal Click-Through API, works fine, but when a user uses this, I can't see their username or email address in the Meraki Portal Client List...I see their mac address and device hostname, but not their username and/or email address.
I would like to monitor users in case of misuse, but trying to do that when you can only see a mac address or hostname (which some devices have horrible host/device names) is not an option/viable.
Does the API allow this, or should I post a username variable or use another API that will allow this?
Regards,
Dawid
3 REPLIES 3
Re: Captive Portal API - Click-Through - Can a email address be passed to the API
I don't know if this will work - but have you tried adding the "User" column under Network-Wide/Clients?
Just browsing
Philip,
Thanks for the advice, but no, I have already enabled the column for the username.
Dawid
When you say "click-through" where are you capturing the username/e-mail. The thing with click-trough is that they just need to click a button acknowledging you're usage policy and that's it. So there would be now way to get that info in dashboard. Or am I misunderstanding the situation?
