Search instead for
Cannot get list of devices
MW3
Im trying to implement the api, I can get everything else such as list of Orgs, admins within an Org, however cant get list of devices as it returns empty even though there are devices visible on the dashboard.
So, this is working with same header (X-Cisco-Meraki-API-Key):
{{baseUrl}}/organizations/{Org-ID}/admins
But these are not even though the header x-cisco is the same:
{{baseUrl}}/organizations/{Org-ID}/inventory
{{baseUrl}}/organizations/{Org-ID}/deviceStatuses
{{baseUrl}}/organizations/{Org-ID}/devices
So what am I missing?
Accepted Solutions
MW3
Re: Cannot get list of devices
Ok guys thank you so much for the help, ive figured it out using good ol google search..
https://community.cisco.com/t5/mobility-discussions/meraki-dashboard-api-confusion/m-p/3458242
Took 3 days to figure it out and thats mainly because none of the super extensive guides mentions that there is a difference between "meraki" devices and "system Manager" devices!!
https://documentation.meraki.com/zGeneral_Administration/Other_Topics/The_Cisco_Meraki_Dashboard_API
https://developer.cisco.com/meraki/build/meraki-postman-collection-getting-started/
While the only place there is something `SM` has over 500 links on the menu.. you wouldnt expect me to go though all of them to figure it out!
https://documenter.getpostman.com/view/897512/meraki-dashboard-api/2To9xm?version=latest#intro
But anyway, thanks a lot for looking into it.. really appreciated, you guys are awesome Smiley Happy
16 REPLIES 16
Within Postman, its written like this and working:
{{baseUrl}}/organizations/{{organizationId}}/deviceStatuses
Same with the others in your list
MW3
Thanks for the reply. So when I say `{Org-ID}` I mean I manually put in the org id myself. So its a placeholder just to explain the issue. And also note its working for `admins` endpoint!.
MW3
Here.. see?
Are you sure you are in the correct envirement and the correct Organization ID? Maybe you have got more than one (orgs / envirements)?
as Postman is not giving any error message and just not giving back any data this may be a problem.
MW3
If there was a prob, it wouldnt get me `admins` and a lot of other things Smiley Happy
MW3
{{baseUrl}}/organizations/{{organizationId}}/admins
So this works perfectly
nope, as if you have more Organizations in your dashboard and an empty one it would still show you the admins, but no output on devices... Smiley Wink
API is allowed in dashboard? I am sure but just want to ask... Smiley Wink Org - settings - Dashboard API access
How did you get your Org ID? Postman?
correct base Url? https://api.meraki.com/api/v0
MW3
hmm
1) Ive got devices in the dashboard for the orga. Also I tried other org it always return the same.
2) I got the list of orgs by calling this:
3) I can assure you I dont have multiple or wrong org id in the environment.
MW3
and also,
4) Yes the baseurl is correct
5) Ive granted access to the api. Also I deleted the access key 3 times and generated new ones just in case.
Smiley Happy
MW3
mmmhh...
I am out Smiley Very Happy Smiley Sad Sorry...
maybe the Pros need to take a look... @BrechtSchamp @NolanHerring @AjitKumar @jdsilva @PhilipDAth for example
The account from which you're using the API key, what usage rights does it have? Check in Organization > Administrators
@MW3 What is your output if you run this command directly?
curl -L -H 'X-Cisco-Meraki-API-Key: <key>' -H 'Content-Type: application/json' -X GET 'https://api.meraki.com/api/v0/organizations/{organizationId}/devices'
Please replace "<key>" with your API Key (don't include '<>') and replace "{organizationId}" with your Org ID (don't include '{}')
Please share the output and we will see what the issue is
MW3
Yea account has full access to the network.
MW3
MW3
