Hi, I have different networks all sending CMX data to different HTTP endpoints but only one network, after some time, stops sending data with no error on the dashboard. I have to validate again the endpoints and change something to save again the settings. After this the CMX data are sent again.
Has someone experienced this kind of problem?
Solved! Go to Solution.
This happens when the Meraki system tries to send data to your solution, and it experiences a number of errors or it takes a long time to respond. This causes it to give up.
https://documentation.meraki.com/MR/Monitoring_and_Reporting/Troubleshooting_the_Scanning_API
If an endpoint is taking an exceptionally long time - 500ms or longer - to respond to a POST, that endpoint's information will be dropped without being sent. It is recommended that applications separate processing of incoming Scanning API data from data routing for this reason.
