Search instead for
Block device from API
Hi All,
I'm creating an App that can be rolled out to our Service Desk and Security Team to allow them to manage users devices etc. on our networks from the API.
One of the bits i'm looking to do is block a device from the network if we see any malicious activity etc. being conducted on that device. However, i'm unable to find what the policy ID maybe for the in built Meraki Blocked policy.
I've checked a device that is blocked on a network from the API and it says normal, even though on the dashboard it is actually blocked with a custom message being presented to it. Smiley Frustrated
Any one had this issue before and can maybe shed some light on this?
Thank you!
Cheers
N
Accepted Solutions
Re: Block device from API
You might be looking at per-SSID policies. The Dashboard API can set a client device to a Group Policy but not specific to an SSID. If you just need to block a user, then set a Group Policy to the device with strict limits or just set it to "Blocked"
Related API endpoints
You can find the available Group Policies for a network and their respective ID
https://developer.cisco.com/meraki/api/#/rest/api-endpoints/group-policies/get-network-group-policie...
To assign a policy to a new or existing client
https://developer.cisco.com/meraki/api/#/rest/api-endpoints/clients/provision-network-clients
To assign a policy to an existing client only
https://developer.cisco.com/meraki/api/#/rest/api-endpoints/clients/update-network-client-policy
important params
devicePolicy
String
The policy to apply to the specified client. Can be 'Whitelisted', 'Blocked', 'Normal' or 'Group policy'. Required.
groupPolicyId
String
The ID of the desired group policy to apply to the client. Required if 'devicePolicy' is set to "Group policy". Otherwise this is ignored.
Example using the provision endpoint (works for all clients)
POST /networks/{networkId}/clients/provision
Body: Provision as Blocked
"mac": "00:11:22:33:44:55",
"name": "Miles's phone",
"devicePolicy": "Blocked"
Body: Provision as Group Policy
"devicePolicy": "Group policy",
"groupPolicyId": "99"
Hope this helps!
4 REPLIES 4
important params
devicePolicy
String
groupPolicyId
String
Hope this helps!
Thats the fella!
Thank you!
Actually, is there a way to add in the blocked note when sending the API POST?
@NeilB Do you have a GitHub repo I can reference? This sounds awesome!!
