Search instead for
Attempting to Change PSK of SSID with Meraki API via Powershell - error 400 Bad Request
Hello All,
I am trying to change the PSK of my SSID using the API.
However, I am getting this error message.
Any help would be greatly appreciated.
I've pasted the code below.
VERBOSE: PUT https://n249.meraki.com/api/v0/networks/xxxxxxxxxxxxxxxxxxxxxxx/ssids/6 with -1-byte payload
Invoke-RestMethod : The remote server returned an error: (400) Bad Request.
At D:\Change_PSK.ps1:37 char:1
+ Invoke-RestMethod -Method Put -Uri $Merakiuri -Headers $header_org -B ...
+ CategoryInfo : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-RestMethod], WebException
+ FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeRestMethodCommand
[System.Net.ServicePointManager]::SecurityProtocol = [System.Net.SecurityProtocolType]::Tls12 -bor [System.Net.SecurityProtocolType]::Tls11
$date = Get-Date -format "yyyyMMdd"
#$DateStr = $date.ToString("yyyyMMdd")
Write-Host $date
#Meraki API KEY
$api_key = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
#Meraki Network URL
$network_id = "xxxxxxxxxxxxxxxxxxxx"
#Base API URL
$api = @{
    "endpoint" = 'https://api.meraki.com/api/v0'
#API URL for SSID PSK Change XXX
$api_put = @{
    "endpoint" = 'https://n249.meraki.com/api/v0'
$header_org = @{
    "X-Cisco-Meraki-API-Key" = $api_key
    "Content-Type" = 'application/json'
# PSK = New password
$data = @{
    "psk" = 'NewPassword' + $date
Write-Host $data
#Convert data to Json format
$jbody = ConvertTo-Json -InputObject $data
#URL Network_ID and SSID number
$api.ssid = "/networks/$network_id/ssids/6"
#Combine base api_put URL and $api.ssid
$Merakiuri = $api_put.endpoint + $api.ssid
Invoke-RestMethod -Method Put -Uri $Merakiuri -Headers $header_org -Body $jbody -Verbose
Accepted Solutions
Re: Attempting to Change PSK of SSID with Meraki API via Powershell - error 400 Bad Request
That's because the SSID is probably set to open.
Try adding these to the code:
$data = @{
    "psk" = 'NewNewPassword' + $date
	"authMode" = 'psk'
	"encryptionMode" = 'wpa'
	"wpaEncryptionMode" = 'WPA2 only' # you could also use 'WPA1 and WPA2'
Or set it up via dashboard before running your script the first time:
2 REPLIES 2
$data = @{
	"authMode" = 'psk'
Thank you very much for your response.
It worked like a charm.
The PSK is now updating properly.
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
