Search instead for
Anyone forwarding MX syslogs to logstash or ELK?
Just seeing if anyone if forwarding their MX logs to Logstash ->Elastic.  I am looking at writing the filters for MX logs but I don't want to reinvent the wheel.  Did a quick google/github search and didn't see anything obvious.
I am just playing with the SOF-ELK VM ( https://github.com/philhagen/sof-elk ) and it doesn't parse the Host name or other message date with an available filter. Thoughts are welcomed on any experience on this topic.
Accepted Solutions
Re: Anyone forwarding MX syslogs to logstash or ELK?
I had previously used some of the following to get the messages from MX / MS parsed (took some tweaking) but I was using logstash to pump log into another app... might be easier going to Elastic (I'm actually about to go thru the process again for a lab - will post on github if you are interested)
https://ioshark.net/logstash-from-scratch-parsing-cisco-meraki-logs-70b8e91c0c68
https://github.com/cs3gallery/meraki_logstash
https://github.com/siemonster/logstash/blob/master/40-cisco-meraki-filter.conf
theres also a Meraki Beats docker app that hits the API - docker pull ciscodevnet/merakibeat
/d
2 REPLIES 2
/d
Dain,
Thank you. These are exactly the type of resources I was looking for.  I appreciate the help.  Keep me posted on your progress for your lab setup, I am always looking to contribute if would like help.
Chad
This is me on github:
https://github.com/chadmando
