API support for Adding Floor Plan / OSPF configuration / Switchport Link Aggregation
jpark5591
I was going thru the Dashboard API document ( https://dashboard.meraki.com/api_docs ) and could not find APIs for the following functions that are available from the Dashboard GUI:
-  Add/Create Floor Plan
- OSPF configuration
- Configure Switchport Link Aggregation
If these functions are currently not supported, are there plans to add them in the future?
Thank you
1 Reply 1
BrechtSchamp
Don't think any of those are available today indeed.
Maybe @Melissa can hop in to give some feedback.
