Search instead for
API l7FirewallRules not working
I am doing an API get for L7 firewall rules. I can do L3 firewall rules and everything else, but the L7 sends back a 404.
Accepted Solutions
Re: API l7FirewallRules not working
OK, I will open a ticket on it.
Thought I would ask the group first.
 I will let you know.
6 REPLIES 6
Can you share the code or call you are using?
I am using Postman and l3FirewallRules work fine.
I removed my key and shorten the network ID
GET /api/v0/networks/N_6558366957/l7FirewallRules HTTP/1.1
Host: api.meraki.com
X-Cisco-Meraki-API-Key: XXXXX
Content-Type: application/json
cache-control: no-cache
Postman-Token: f217d697-1c46-4dee-bec2-1a97383ccff4
I have the same. I wonder if it's not enabled for everyone yet. The command is new since this month.
Open a ticket with TAC.
There is a patch that they will need to add to the Org. they said to open a ticket for each ORG?
Thats going to be a lot of ticket.
I am officially bummed out. I filed a ticket to see about getting this end point enabled for my orgs, only to be told it's not an endpoint and there's no ETA on it.
It still shows up in the Postman docs. I swear it used to be in the ones on create.meraki.io change log too? I guess it's time to be patient.
