API - get snmp ifOperStatus (if a client is connected to port)
CiscoUser
Hi guys,
1. Is there an API call to get port information from a switch network, besides
GET /devices/[serial]/switchPorts
I want to know if there's a client connect to it, like snmp ifOperStatus, without calling for clients specially for that.
2. Also if there is an API call with sent and recieved amounts, such as InOctets/OutOctets, for port.
there is something similar in
GET /devices/[serial]/clients
"usage": {
"sent": 80,
"recv": 106
Thanks in advance
1 Reply 1
TWoz
Hi CiscoUser,
I will attempt to address your questions below:
In regards to the 1st question. Currently, the API call you referenced is the correct API for port information. At the moment there are no alternatives.
as for the 2nd, there are currently no API calls that will provide the in/out octet count in the manner an SNMP get would provide.
Our API systems are always growing, we recommend that any feature requests for additional API functionality be submitted through the "make a wish" window located on the bottom right corner of any dashboard page.
If my post answered your question please click the Kudos button below. additionally,
please update this thread to solved so others can benefit from it
