Search instead for
API PUT blockedUrlCategories won't update. Comes back with not valid
Trying to update blockedURLCategories I followed the example at the website and I get back blockedURLCategories is not valid. this is using the put request.
If i do a get, works find.
"allowedUrlPatterns": [
"http://www.example.org",
"http://help.com.au"
"blockedUrlPatterns": [
"http://www.example.com",
"http://www.betting.com"
"blockedUrlCategories": [
"id": "meraki:contentFiltering/category/1",
"name":"Real Estate"
"id":"meraki:contentFiltering/category/7",
"name":"Shopping"
"urlCategoryListSize": "topSites"
1 REPLY 1
Re: API PUT blockedUrlCategories won't update. Comes back with not valid
I have the same behavior. Feels like a bug.
If you take away the contents of blockedUrlCategories it works:
	"blockedUrlCategories": [],
