API Call for MX LAN IP NO VLAN
bowersjj
Is there an API call for POST/PUT LAN IP address of an MX that isn't using vlans?
bowersjj
Meraki support verified there is no API endpoint for modifying the MX subnet without having VLANs enabled on the network.
Feature request has been submitted.
MacuserJim
Something like this? This API will allow you to set the MX IP of that VLAN.
I typically use Python so here is a link to the Git for that. (if you search the page for "updatevlan" you'll find that API) - https://github.com/meraki/dashboard-api-python/blob/master/meraki.py
Then here is the postman API documentation for that as well (the screenshot is from here) - https://documenter.getpostman.com/view/897512/meraki-dashboard-api/2To9xm#eaad6d04-2a0b-0c4b-fc37-87...
This applies to "Vlans Disabled: Use a single LAN configuration"
API call to getvlans for a MX single lan configured with an IP shows ['VLANs are not enabled for this network'].
The assumption is if getvlans can't see a configuration, then addvlan will fail as there is no 'id' or 'name' to reference.
There doesn't appear to be an API call for a single lan configuration scenario.
Where you at Meraki?
bowersjj
