vMX Integration with PaloAlto in Azure and AWS environment
Par_23
Hi Team,
We have prepared solution that Spoke should access Azure Environment Application. In Azure PaloAlto is deployed and behind that all application are hosted and vMX are deployed in Azure AutoVPN with Spoke MX.
Here we are looking best practice vMX Integration with PaloAlto via OSPF or BGP ? which protocol is best and easy configure it so spoke can access Azure Environment Application without any latency issue.
Regards
PP
2 REPLIES 2
If it is in Azure it is unlikely you'll need to use any routing protocol.  I wouldn't use one.  You'll just add the Azure subnets into the Meraki portal for the VMX.
Hi Philip
Thanks for your reply.
Here Applications are behind the PaloAlto and client want to secure spoke traffic via PaloAlto so what will be recommendation for BGP or OSPF ?
Regards
PP
