vMX Azure
BS
vMX Azure
Hi all,
Im looking for some inputs on the vMX in Azure.
To achieve SD-WAN, circuit diversity which type of internet connection I should select in the pricing, is there HA available in the vMX ?
Regards
BS
Accepted Solutions
Re: vMX Azure
vMX is not free.
You need to buy a licence from Cisco Meraki to use it (like all other Cisco Meraki kit).  You also need to pay Microsoft Azure for the virtual machine charges and data traffic.
8 REPLIES 8
Re: vMX Azure
HA is not available with vMX in Azure.
I wasn't aware Azure had different types of "Internet circuits" available to choose from - what are your options?
BS
Re: vMX Azure
Hi Philip
Thank you for the response.
Even I'm not sure, I'm aware that there are Internet pricing
https://azure.microsoft.com/en-us/pricing/details/bandwidth/
My scenario is that I got 11 branches and most of my application stack will be with Azure, Instead of going through Internet breakout and accessing the apps, I feel let these branches connect to a vMX in the Azure so that the performance will be slightly better
In this scenario which internet option I need to choose, could you please guide.
Re: vMX Azure
This is simply what Azure will charge you for bandwidth.  You don't get to choose anything.
Yes, a vMX in Azure would be a good choice.
Here are the deployment instructions:
https://documentation.meraki.com/MX/Installation_Guides/vMX100_Setup_Guide_for_Microsoft_Azure
BS
Re: vMX Azure
Thanks Philip, as a newbie in meraki  I was confused and thought I need to consider separate internet connection to receive Public IP on my WAN Interfaces.
vMX was mentioned as free of cost along with other azure workloads.
Re: vMX Azure
vMX is not free.
Re: vMX Azure
@PhilipDAth wrote:
vMX is not free.
Philip is right. The only thing "free" about the vMX is the VM image itself.
MRCUR | CMNO #12
Re: vMX Azure
All true. If I recall the pricing the license for the vMX is $5000 list price.
There is no HA for the vMX Azure will fail over to another host if required by a failure event. It is also a single legged device with both private IP and public like other Azure servers.
I've had one running now for 6 months with limited issues. All being on the Azure side due to host problems and the wonderful SouthCentral outage last month.
In all the vMX on Azure works quite well.
I hope this helps.
-Dennis
BS
Re: vMX Azure
Thanks Dennis
