vMX AWS bi-directional communication
OSPF71
Set up a vMX for the first time in our AWS account. Can communicate from any subnet in our corporate LAN to the windows servers on our VPC, but cannot communicate from the servers to any subnet beyond the vMX. Thought it was a ACL rule somewhere. Have tried explicitly allowing icmp but must be missing something simple. Any ideas from AWS experts?
OSPF71
After placing a ticket with AWS and verifying that the AWS side of the network was configured correctly, I submitted a case to Meraki support. Thanks to the tech who had me place the vMX into pass-through mode from routed in deployment settings. Just added the local AWS subnet to be advertised and it works as expected now.
5 Replies 5
MyHomeNWLab
1. What is the Mode of vMX?
I was curious because the default vMX mode has recently changed.
vMX Setup Guide for Amazon Web Services (AWS) - Cisco Meraki
https://documentation.meraki.com/MX/MX_Installation_Guides/vMX_Setup_Guide_for_Amazon_Web_Services_(...
> Change in default behaviour
> All new vMXens deployed post October, 31, 2022 will be deployed in Routed/NAT Mode Concentrator by default, existing vMX deployments will not be effected. If you wish to use the vMX in passthrough mode, please change the deployment settings to Passthrough or VPN Concentrator mode from the Security& SD-WAN > Configure > Addressing & VLANs page.
2. Have you set up a Route Table for return traffic on your AWS VPC?
When configured in Limited NAT mode, only communication from the corporate LAN to the Windows Server on AWS is possible without setting a return route.
Conversely, the AWS side will not be able to communicate with the corporate LAN.
The reason is that in Limited NAT mode, addresses on the corporate LAN side are hidden by the source NAT.
The vMX is in default mode per the guide you reference, which I used to configure and deploy the vMX. As far as the route table, yes, I added a route table with all available subnets with the target as the vMX instance.
The #1 problem I run into with this issue is  - Windows firewall on the host.  Try disabling it temporarily to see if the issue is resolved.
Do you have any Meraki organisation VPN firewall rules that could be at play?
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-site_VPN_Firewall_Rule_Behavior
I don't clearly understand.  You can talk to the machines in the VPC behind the Meraki VMX.  Are these other machines you can not talk to located in the same VPC or a different VPC?  Have all the subnets (at least in the same VPC) got the same AWS route table associated?
-That was the very first thing I did before looking at ACL's and Security group settings.
-None
Currently, the vMX is setup as a spoke connected to a specific data center hub. I can communicate from any subnet in the corporate LAN that is connected to that DC hub, to the servers in the VPC. The servers and vMX are in the same subnet. The subnet is associated with the routing table. The servers in the VPC need to talk to the servers in the DC hub but cannot. Looks like traffic is dropping off at the vMX.
OSPF71
