how to route traffic over non meraki peering links?
DevilWAH
Hi
I have a MX68 device that has a non meraki peering to a physialc network (MX-A)
Secondly I have a secone MX68 (MX-B) that has a meraki peering to MX-A.
So all networks 10.0.0.0/8  are on the other side of the non meraki peering.
I would like MX-B to send traffic destined to 10.0.0.0/8 to MX-A, but I cant remember how to do this, by defualt MX-A does not advertise the toure it has to 10.0.0.0/8 to other meraki peers and I cant set a static route that has a peer as the next hop.
I did set the hub to be "default" route but this still does not work. Any ideas.
2 Replies 2
GIdenJoe
You cannot route between AutoVPN and IPsec VPN.
So traffic coming from an IPsec peer cannot be tunneled back over an AutoVPN and vice versa.
If you want MX-B to reach the non-meraki peer you have two options:
1) You also peer directly between MX-B and the physical network.
2) You have another way to route from MX-A to the physical network like a LAN route.  Then you can use point your routing table to the next hop in a static route and make that static route available through the AutoVPN.
Tadpole86
Peering directly from MX-B is likely your best option.
What you are trying to do will not work for the already mentioned reason
