Hello all,
This should be resolved now. The file has been mistakenly categorized as malicious causing this to fail. File deposition has been changed. We are truly sorry for the inconvenience. If the updates are failed, please go ahead and try again, they should go through now.
As of now, this is only related to Microsoft files. if you are also seeing issues with Adobe files or any other files. They should be considered as a different issue and please open a ticket with Meraki support for further investigation.
Regards,
Raj
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
