VPN of meraki Full stack
Hi All,
can somebody enlighten me on my meraki for 2 sites? Below are the details;
for Main office (HUB already enabled)
1-MX84
3-MR33
1-MS
for branch (Spoke?)
1-MX64
2-MR 18
1-MS
if I enable the site-to-site VPN will all other meraki appliance be included with the VPN?
5 REPLIES 5
Re: VPN of meraki Full stack
Hi! The VPN you connect between your sites will only add the subnets you allow between the vpn connections.
If you have one subnet spanning all devices, then yes, all Meraki appliances will be included 😉
Hi @ludwigbery
I understand when we establish "Site-to-site" AutoVPN between two locations.
The Local Subnets (included In VPN) are exchanged and the devices belonging to these subnets can talk to each other.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
You have to set at least one site to be a hub.  The second site can be either a hub or spoke.  Once you have done that they will built a VPN automatically.
@Rebry
@AjitKumar
@PhilipDAth
thank you so much for the inputs!
