Search instead for
Template for only Group Policies
Hey all,
New to Meraki so be gentle. I'm would like to have a configuration template of sorts, that would only link the group policy configuration. I don't want it to modify the VLAN/Addressing configuration or really anything else. But i would like one place to change group policies, and have wherever it is assigned have it update everywhere. Make sense?
Re: Template for only Group Policies
There isn't a way to template only group policies. You could look into using APIs or Systems Manager.
I believe this may not possible.
Configuration Templates do have the feature however I do not see an option to choose what to apply and what not to apply. The networks binded to a Template shall inherit the complete configuration.
APIs can only display the List of Group Policies in an network.
I understand this job shall me done manually as of now.
Cheers
Ajit
ajitsnw@gmail.com
The others are correct.
The best way to do dynamic group policy assignment is using RADIUS.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_...
You use the FilterId attribute.
If this is for WiFi you ideally want to be using WPA2-Enterprise mode.
If this is wired you want to be using 802.1x.
