Routing b/w Appliances!
khurram
i have network which contains cisco switches and MX67 appliance and all are interconnected through switch. I want to advertise my routing table between all security appliances. We can do that in Cisco Routers through routing protocol but how we can achieve the same in MX?
khurram
Thanks for the reply. devices are locally connected and i do not want to do it through auto-vpn. I want to do it through some routing protocol.
It is static routes for you then, no OSPF listener on MX.  There is a support enabled option of BGP, though not sure that'll work with your topology.
