Monitoring One-armed concentrator
mat1458
Another basic question (after having brought up the one armed concentrator with SSID tunnels):
Is there any possibility to see how many SSIDs/Access Points have active tunnels to a MX VPN concentrator? I did not find anything in the portal so far, maybe API?
2 REPLIES 2
I've never used AP's in AutoVPN mode; but normally if you go "Secureity & SD-WAN/VPN Status" you can see the AutoVPN connected sites.  Do the APs show up there?
Hi Philipp
That's where I expected to see them but it seems that this is for site-to-site AutoVPN type of connections to other MXs only. It seems that apart from the "Test Connectivity" button in the SSID configuration panel there is nothing to show that the connection is working. And the results of "Test connectivity" are not easy to interpret, especially failed ones.
But thanks anyway for your answer.
Mat
