Hi Guys,
Could you please confirm below
LIC-VMX100-1YR is similar features as Enterprise or Advance License of MX?
because there is only sigle SKU available.
Solved! Go to Solution.
Hi @Mohammad
Unfortunately not, all MXs (apart from vMX) have to be of the same license type. Also there are now three types for physical MXs; Enterprise, Advanced Security, and Secure SD-WAN Plus.
It is more like an enterprise license. A VMX is designed to allow an Azure or AWS network of servers connect to a Meraki SD-WAN that includes your existing sites and clients. It isn't designed for end user protection as you wouldn't usually have clients behind it (perhaps cloud VDIs, but that would be the only case I can think of).
Thanks Man,
If customer have existing environment of Meraki MX of Enterprise or Advance security Licenses, VMX would be work with them in both cases from single Dashboard?
Yes it can be in the same organisation and it would have it's own network. Each network can only have one MX config (including one HA pair).
@cmr Thanks Mate.
Very much Clear.
I have one more question with different scenario.
What i know, that organization can only have all MX devices with either Enterprise or Advance security Licenses, not both of them in single Organization Dashboard.
Can we Mix Ent and Adv licenses in one Organization under different Network group?
Hi @Mohammad
What are SKUs for Secure SD-WAN Plus?
LIC-MXmodel-SDW-duration
LIC-MX84-SDW-1YR not working?
Thanks Mate, its working now.
But any idea, why they put this part number with out R LIC-MX84-SDW-1Y ever every other part numbers have R?
No idea but it started back when LIC-MS125 where introduced.
Our Company at present using Cisco Meraki MX68W. however, our license terminated in 7 days. thus, we can't locate a region Meraki partner outside the USA,
our company located in ‘Ethiopia’ would you be able to discover the closest affiliate. therefore, that we can purchase a license online.
Kindly see the details of the order.
LIC-MX68W-ENT-1YR
Hi
As you mentioned you should be fine just purchasing the renewal from anywhere in the world.
if local partner is required visit partner locator and sort out
https://locatr.cloudapps.cisco.com/WWChannels/LOCATR/openBasicSearch.do
