Meraki SD-WAN
MediaCreations
Meraki SD-WAN
In a Demo I try to create a SD-WAN via Site-to-site VPN, but I can't...
Connectivity: Disconnected. This security appliance is currently unreachable from the Meraki cloud.
Anyone can help me?
I Request a demo, and create 2 networks... Then I create in each network a mesh and nothing happen...
6 REPLIES 6
rwiesmann
Re: Meraki SD-WAN
First step would be, that the MX will reach the Meraki cloud.
Make sure the management protocols meraki uses are not blocked.
For more details on the ports, check out this document
https://documentation.meraki.com/zGeneral_Administration/Other_Topics/Upstream_Firewall_Rules_for_Cl...
ones this is good...we can go a step further.
rgds
roger
Re: Meraki SD-WAN
The appliances don't need to be online to configure AutoVPN.
Where are you seeing this error?  On the local status page?
MediaCreations
Re: Meraki SD-WAN
Can you show me how to do this?? Like a youtube video...
MediaCreations
Re: Meraki SD-WAN
Re: Meraki SD-WAN
its some kind of dummy demo dashboard that does not really have a internet connection. if i login there i also cant ping 8.8.8.8 or use dashboard throughput test.
so i guess that part of the demo is not working .
MediaCreations
Re: Meraki SD-WAN
And how can I resolve that?
