请问MX100防火墙的日志可以保存多久,是否任何操作或者被攻击都会有日志记录,如果想联系技术工程师该如何做?
Solved! Go to solution.
The Meraki Dashboard maintains logs for up to 3 months.
I highly recommend having an on-prem syslog server that all devices send logs to as it will include more detail than the standard event logs.
In regards to contacting technical support, you can open a case via the dashboard or call the support number.
thank you for help, may i ask how to setup on-prem syslog server?
From the Meraki side it's relatively simple, you just tell it where to send the logs
In terms of setting up a syslog server, there's multiple options out there - paid products and open source.
The basic premise is the same for all, they simply ingest logs. The main differentiator is the interface, ease of deployment/use, filtering and alerts etc.
Some popular ones include graylog, ELK, nagios, splunk, kiwi.
Thanks a lot.
hi, thanks for help, I have check with my MX100, but I can't find the syslog function, would you please help to find where the syslog is in MX 100?
hi, thanks, I found it.
