Meraki Insight & vMX
johnnyngena
For vMX deployments, is a Meraki Insight license needed if a Meraki Insight is opted?  Any documentation or rules on this?
DarrenOC
Hi @johnnyngena , if you require Insights then an Insights license is required
https://meraki.cisco.com/lib/pdf/meraki_datasheet_mi.pdf
5 REPLIES 5
DarrenOC
Thank you UCcert!
GreenMan
You mentioned vMX in your Title;   you can't run MI on vMX.
Remember that MI works by sitting on the boundary between the HTTP client's LAN and that site's WAN link.
The vMX sits at the opposite end of the HTTP connection - adjacent to the server.
See "Where should I enable Meraki Insight?" here:
https://documentation.meraki.com/MI/Meraki_Insight_Introduction
GreenMan, so basically MI is ran on the customer's premises or LAN, not in the cloud where the vMX sits?  If yes, then Meraki Insight license does not apply to a vMX, correct?
Correct - MI runs on the MX appliance 'near' the client, not on vMX.
