MX WAN connected to a load balancer
wmchong
Hi everyone,
Was wondering how you guys handle customer with more than two Internet uplinks.
If I have say 3 Internet links going into a load-balancer, which in turn connects to the MX WAN port, would the AutoVPN work?
Thanks!
2 REPLIES 2
Adam
I've never tested this but my guess is the VPN tunnel would establish through one of the WAN links and hold its session open there.
How do I handle it?  I replace two of the 3 connections with 1 better connection.
It's not worth the extra grief of having another box to maintain.
