MX 64 with failover
Just browsing
MX 64 with failover
Looking at putting in an MX64 with the Accelerated 6310-DX03 LTE option for cellular failover. Wanted to know if a prepaid cellular plan can be used with this or does it have to be sometime of monthly plan with one of the carriers?
4 REPLIES 4
Meraki Alumni (Retired)
Re: MX 64 with failover
The hardware doesn't care what type of plan the cellular service provides, only that the modem is compatible with the hardware. Provided it is - the plan you choose to use doesn't mater
Looks like that device will just look like another WAN connection to the MX.  Are you wanting to just use this as a backup circuit or active/active?
What speed do you want the LTE device to operate at?
As @ChrisKemsley said, it doesn't car about what plan you want to use.  It just needs IP connectivity to the Internet.
