I have a site to site connection setup but between two buildings and it seems that there is traffic but when I ping a computer on the other end I get nothing. Subnets do not overlap and appropriate subnets are enabled. NAT is set to auto on both ends. Firewall rules look to be okay. What trouble shooting steps should I try to test and resolve this issue? Any help is appreciated.
To your first question, I am not sure. I will try and figure out a way to check on that. To the second question, no I am not able to ping vlan ip of the remote subnet. Using Meraki I can see that the status on both sides are good and I can see that there is source and destination traffic. I am very new to networking and understand most basic concepts so maybe I am just skipping or missing something obvious lol.
I checked again on the firewall rule and they seem to be okay. Yes I can ping the remote gateway. Trace route shows that I am connecting to the gateway while only showing one hop over the network. Some of the others do not respond to trace route it seems.
Thank you for the assistance. Through some troubleshooting I found that the subnet that I was connecting from was not enabled to use the VPN. After enabling I was able to connect just fine.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b51492e91658a","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b51492e91658a_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b51492e91658a_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b51492e91658a_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6b5149264a6272","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
