IS vpn translation possible with MX in vpn concentrator Mode?
Customer utilizes vpn translation with their Cisco asa 5510 to about 10 of their clients as the customers' internal ip range overlaps with their clients. Can we set up a 2nd MX as VPN concentrator and do something similar? I believe I have seen a document on this but I can't put my hands on it.
5 REPLIES 5
Re: IS vpn translation possible with MX in vpn concentrator Mode?
You mean like this?
https://documentation.meraki.com/MX/Site-to-site_VPN/Using_Site-to-site_VPN_Translation
Yup, it's supported in concentrator mode. It's just non-Meraki VPN it's not supported in.
Unfortunately, they are all non Meraki vpn peers.
Are you able to do the translations on the non-Meraki end?
Not sure what the status of that would be, but I would say probably not.
I know it's a pain but I'd recommend checking in with your remote peers to see if they can do it. Otherwise, sadly, you're going to be out of luck.
VPN NAT for third-party VPNs is on my wishlist.
