Guest Ambassador
Guest Ambassador
Hi
I'm trying to figure out the complete privilege of a Guest Ambassador
int the doc :
Guest ambassador: User only able to see the list of Meraki authentication users, add users, update existing users, and authorize/deauthorize users on an SSID or Client VPN. Ambassadors can also remove wireless users, if they are an ambassador on all networks. The existence of network templates anywhere in a dashboard organization prevents guest ambassadors from deleting wireless users.
Presented with user management portal only.
My question is does a Guest Ambassador is able to create a new client vpn and authorize it ?
thanks,
4 REPLIES 4
Re: Guest Ambassador
Hi @Jeizzen , the Ambassador can only setup, delete and authorise users.  They can’t configure services such as VPN clients
Darren O'Connor | uccert.co.uk
Hi UCcert,
But if the client vpn service is already enabled, the admin in Guest Ambassador mode should be able to create and authorize client vpn users ?
thanks ,
Hi @Jeizzen , are you asking if the Ambassador can add new users and authorise them to use the Client VPN?  If so the answer is yes
yes
that answers my question
thanks,
