Client VPN reporting help needed
RYN0
Hi All,
I am trying to figure out if it is possible to automate pulling specific event log data for client VPN connects and disconnects, periodically.
I know how to pull the data manually from the dashboard, but this can be a bit tedious.
Not sure if trying to figure out if there is an API that can do this, or if it may be better to get a good syslog server instead.
Anyone else running into this issue? If so what solution did you use to help yourself out with?
Thanks,
RP
1 Reply 1
This API call would probably give you what you need.
https://dashboard.meraki.com/api_docs#list-the-events-for-the-network
If you are new to Python or APIs check out this quick start guide.
https://developer.cisco.com/meraki/api/#/rest/guides/python-sdk-quick-start
