Client VPN Appliance configuration
JED2021
My current client vpn configuration uses
192.168.0.0/24.
I want to change that assigned subnet.
The setting area states refer to layer 3 subnet. but 192.168.0.0 is not listed.
Is there a simple guide to MAINTAIN every setting however just change the subnet to 192.168.250.0 or some other RFC1918 address?
2 Replies 2
You can just change it.  Nothing special.  Just needs to be unique in your network.
Andre_Afonso
Like just  Philip say you can change VPN network and that need to be unique.
That means the network have to be configure only in the Client VPN tab and you don´t need to configure the same network on the Addressing&Vlan.
Check this doc.
https://documentation.meraki.com/MX/Client_VPN/Client_VPN_Overview
Andre Afonso
