Aws Vmx can't reach the cisco dashboard
mclovin
Just browsing
Hi all ,
I have deployed a vmx instance from my AWS account , the instance is working properly and join internet.
However is impossible to reach the meraki dashborad with the message :
From Aws All my vpc and security groups sounds good
Someone already met this problem ?
3 REPLIES 3
MilesMeraki
Re: Aws Vmx can't reach the cisco dashboard
Is it deployed in an AWS VPC with a subnet that has a default route to an AWS IGW?
The security group would allow it to communicate out but you have to make sure the routing is configured inside AWS.
mclovin
Just browsing
Hi @MilesMeraki  ,
Thank you for the answer, I think it is my instance is able to reach internet.
MilesMeraki
Have you followed the setup guide?
https://documentation.meraki.com/MX/MX_Installation_Guides/vMX_Setup_Guide_for_Amazon_Web_Services_(...
"The authentication token must be entered into the AWS Cloud instance within one hour of generating it, otherwise a new token must be generated." Has the authentication token been added to your vMX instance? If not you may have to go through the process to re-add it.
