AWS VPN Redundancy without vMX
Mloraditch
Is there a way to do this? Have multiple sites connect to the Same VPC? It appears not, but figured I'd ask as I know there are some wizards around here.
MacuserJim
I would think you could configure an AWS hardware VPN as redundancy to the vMX, but I've never tried it.
https://aws.amazon.com/premiumsupport/knowledge-center/create-connection-vpc/
If your sites have static IP addresses, you can use the Amazon VPC VPN Gateway service.
https://docs.aws.amazon.com/vpc/latest/userguide/vpn-connections.html
Mloraditch
Thanks both of you for the replies, it appears neither option will exactly work in my scenario. May just have to get the customer to get a vMX.
DaMiBu
You can do this with a dual tunnel Cohesive Network VN3 router.  The have a special offering and configuration for your exact setup.  We use it for our clients and it works really well.  License is considerably cheaper than vMX.  https://youtu.be/RlZ_3g9_5T4
