Meraki Security Camera - MV22 and MV72 - on HP PoE switch and SOPHOS Firewall
SCC
Hi All,
I am planning to use the Meraki Security Cameras MV22 - Indoor and MV72 - Outdoor. But it will be using the HP PoE switch for the physical connectivity and SOPHOS Firewall for the Internet access.
I would like to know will there be any challenge or it should be straightforward once i will connect these Meraki Security Cameras to the LAN (which has the Internet Access already) it should work fine.
Any thoughts or suggestions ???
5 Replies 5
The MX72 needs 802.3at power, so make sure the HP switch is 802.3at.
When you log into the Meraki Dashboard you can go "Help/Firewall Rules" in the top right hand corner.  That will give you the rules to configure on your Sophos firewall.
SCC
Hi Phil,
This is the switch we have got. Will this work?
Product: HP J9773A
Name: HP 2530-24G-PoEP Switch
show power-over-ethernet
Status and Counters - System Power Status
Operational Status : On
Usage Threshold (%) : 80
Chassis power-over-ethernet:
Total Available Power : 195 W
Total Power Drawn : 12 W +/- 6W
Total Power Reserved : 12 W
Total Remaining Power : 183 W
Internal Power
Main Power
PS (Watts) Status
1 195 POE+ Connected
SCC
When i see the datasheet it looks good to me.
https://www.arubanetworks.com/assets/ds/DS_2530SwitchSeries.pdf
SCC
When it comes to SOPHOS Firewall Rules if i will allow any/any from the Security Camera VLAN. Will that not work ?
MarcP
this will work... Or as Philip said, you can configure the following:
Dashboard (top right) -> Help -> Firewall Info
Source IP[Sorting up]
Destination IP
Ports
Protocol
Direction
Description
Devices using this rule
Your network(s)64.62.142.12/32, 108.161.147.0/24, 199.231.78.0/24, 209.206.48.0/207351, 9350UDPoutboundMeraki cloud communication, VPN registryAccess points, Cameras, MX Security Appliance, Phones, Switches
Your network(s)64.62.142.2/32, 108.161.147.0/24, 199.231.78.0/24, 209.206.48.0/2080, 443, 7734, 7752TCPoutboundBackup configuration downloads, Backup firmware downloads, Splash pages, Backup Meraki cloud communication, Throughput tests live toolAccess points, Cameras, MX Security Appliance, Phones, Switches
Your network(s)Any123UDPoutboundNTP time synchronization Access points, Cameras, MX Security Appliance, Switches
Your network(s)8.8.8.8/3253UDPoutboundUplink connection monitorMX Security Appliance
Your network(s)10.1.220.81/321812UDPinbound802.1X with customer-hosted RADIUSAccess points
Your network(s)8.8.8.8/32, 209.206.48.0/20 ICMPoutboundUplink connection monitorMX Security Appliance
