@gcooney14 The mounting hardware included with the MV22 can be used for walls and ceilings alike. In the box there is a base plate (which you do need) and also a junction box mounting plate (which you may or may not need) to accommodate a variety of installs. The data sheet lists a "wall mount" but it can just as well be ceiling mount. Check out the install guide here. https://documentation.meraki.com/MV/Physical_Installation/MV22_Installation_Guide Unfortunately, I do not see the mounting hardware orderable as spare parts. I will make sure suggestion to update the data sheet to say "wall/ceiling mounting kit" and ask if there might be some new SKUs for ordering spare base plates.
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
