Search instead for
Camera VLAN and Local Streaming
Haven't tested so hoping someone knows. If cameras are on their own VLAN, will Meraki be smart enough to still stream locally if the VLAN on I am on (let's say the client desktops / laptops VLAN) can route to the camera VLAN? Or will it just proxy?
cheers all
Re: Camera VLAN and Local Streaming
It will stream locally if it can connect directly, even if it is on a different VLAN.
As long as you have a route to the camera VLAN, you'll be okay.
MRCUR | CMNO #12
