I know enough to be dangerous, but a relative networking novice. Have inherited the following setup for small (approx. 20 employees) office:
Network is setup as follows:
Internet connection from building goes into my MX65W appliance.
From here, the signal is sent to our Meraki GS110-24 switch, which then is wired to 3 different Meraki Go GR10 Access points in various locations in the office.
Currently the MX65 device broadcasts 2 WiFi networks, while the 3 GR10 APs each broadcast 2 other WiFi networks. Our connections will then drop/swtich from the networks broadcast from the MX65, to one broadcast from one of the GR10s (or vice versa) depending on one's location.
I'd like to have every device broadcasting the same 2 WiFi networks, and to be able to roam and switch connections from one access point to another seamlessly, without dropping/reconnecting, and to also to be able to administer everything from 1 admin console.
When in the admin console of the MX65 device, I am unable to 'claim' any of my GR10 access points, as it notes they are Meraki Go devices that have to be administered separately. So it's my understanding what I want I want to accomplish is not possible because the two different product lines (M series vs G) can't be configured like that?
With all that said...what is my best option? I've been given a bit of leeway in terms of buying any new equipment that might be needed. Would replacing the MX65 with a Meraki Go GX-50HW Firewall Plus help solve my problem? Or another product? Looking for advice on the simplest/most effective way to do this.
Thanks in advance for any advice.
