Using Meraki MX in Barcalona
GaryShainberg
Hi there team,
I have a client in Barcelona (I am in the UK) who has a business DSL from Movistar with one of their cr!@£$$ routers which it appears that their fibre terminates on.
They are having problems with thsi router and would either like to by-pass it or replace it.
Is there anyone here that either knows what needs / can be done or can tell me that I am wasting my time and just put up with it !!!
TIA
Gary
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
2 Replies 2
BlakeRichardson
Hi Gary
You say business DSL. Do you mean ADSL or VDSL?  If so Meraki MX units do not support ADSL or VDSL connections.
The reason I ask is you mentioned DSL but you have also mentioned fibre.
Blake,
Thanks - thats my point that the MX does not have a xDSL modem in it therefore in this case, where I have a vDSL fibre connection from Movistar I have to have a vDSL fibre modem ( see image) that I would like to replace with a bridge so that I can do the PPPoE authentication on the MX2bfdc49b-1073-4fe2-99b2-dae7e9236fd0.jpg
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
