MX with Meraki GO switches and AP's
Kal
Are the MX gateways are compatible with Meraki GO MR110-48 switches, GR10 and GR60 AP's? Need to have 2nd WAN port for failover to secondary ISP.
4 REPLIES 4
Do you want to have a 2nd WAN on MX correct? You can connect MX on any switch that you want, and It will work without problem.
Kal
Thank you. I don't see where I can convert LAN1 into a WAN port on the GX20 like I can on the MX units. Just wanted to make sure the MX will work with the other Meraki GO equipment.
Sorry, I thought you were talking about the MX. The GX20 has only one WAN port.
@Kal the MX will work with the Meraki Go equipment, but you'll have two different dashboards and I believe you'll need to use different email addresses with each.  It's sort of like using Meraki Go with a Sophos firewall, everything works, but the two are managed independently.
