Search instead for
Unable to access dashboard
Is anyone else experiencing difficulties access their dashboard?
If so, have you been able to access any support?
I've not been able to do either and am feeling extremely frustrated by this!
If anyone has any information as to when this issue will be resolved or anyone we can contact,I would be most grateful.
Thanks, Terry.
Re: Unable to access dashboard
The shard I am using (n85) is working fine for me.
You can also call support using these phone numbers:
https://meraki.cisco.com/support/
Cheers Philip,
Any ideas as to how I can access support?
When I call the UK number, I get a voice mail telling me to quote my customer number which can be found by accessing the dashboard...
Thanks but I've tried that number.
Usually there is a way to continue on in the IVR without your customer number.
Have you tried connecting to the dashboard using a different method, like 4G?
Can you connect via the Meraki smart phone app?  If you can do that you should be able to get your customer number.
Thanks Philip,
What's the IVR?
I get the same issue when I log on using a mobile network.
Is there any Error message whit your account? Have you tried to acces with another one?
What Philip means about IVR, is Interactive Voice Response, the record that answer you in the Meraki Support line, there may be an option to continue the call without your customer number.
