Search instead for
Split Networks
Split Networks
I have a combined network that I need to split in order to upgrade an MX100 to and MX450. I need to clone the configuration of the MX 100.  If I split the network while it is active will any configurations be lost? Will clients be disrupted?
Accepted Solutions
Re: Split Networks
Yup, you're safe.
Re: Split Networks
No. If you split the appliance network out of the combined network there's no impact.
If you're just doing an upgrade though I would remove the existing MX100 and then add the MX450 instead of messing around with two networks. You'll have to adjust the physical ports configs, and deal with cabling, but I think it's easier than trying to clone the network.
Re: Split Networks
Why is the title of your post, "Client VPN split tunneling?"
I have split combined networks and combined them again and not seen any service interruption or other trouble.  I did this most recently to get rid of an old demo MC network I had in one of my combined networks.  If anything, you *might* lose historical data like client usage.  If that is important, I would call support or research more to find out.
Re: Split Networks
Sorry about the the title . I had suggestions turned on and didn't notice.
Community Manager
Re: Split Networks
@Netwow - I can change the title if you like, just let me know what it should be!
Caroline S | Community Manager, Cisco Meraki | @merakicaroline
Community Manager
Re: Split Networks
Oh, never mind, you did it! :-)
Re: Split Networks
Ok back to the initial question. The reason I want to clone is because there are so many VLANs (cleaning this up later). So I am safe splitting and then re-combining.
Re: Split Networks
Yup, you're safe.
